SOURCE: not printing colour
go to printer then click with the right botton mouse on printer and select printing preferences and click on paper/quality and then click on color and then aply and thats all
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll
need to keep running it untill it runs clear and it uses alot of your
ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
SOURCE: Kodak esp 3 all in one. colour prints come with purple tint
Surely you can turn the flow of ink down via your settings
SOURCE: Kodak ESP-7 won't print Word Art
This isn't a solution, but a workaround...
If you create your word art, you can right-click on it, and save it as a graphic. Reimport the graphic into Publisher and it should print (at least it did on mine).
SOURCE: My printer will not print in black and white, as
Believe or not, a bit of color ink is require to make true black. However, from most application you can go in to the printer preferences and click the Color tab. Check the print in Grayscale and click the Black print only option. My instructs are based on an HP model printer. The preferences can be a little different between brands. But, you should have similar options. Check your printer's manual for more specifics.
