There is a chip on the DMD board that needs to be replaced.Samsung is covering the cost of the part and labor for this problem.Just call 1-800-samsung and they will set up the repair with the closest service center. VERY common problem.
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
