One day I was using the convection portion of my Sharp Carousel convention oven and I opened the door to check the food and closed it, hit the bottom to resume cooking and mechanism to make it turn (whatever that is) quit. I have not been able to get it to turn since. I am willing to take it apart if you think there is a part or something broken. Hope you can help.
Thanks,
Tina
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
SOURCE: I have a Sharp Carousel convection microwave,
microwave's have fuses in them. try and replaceing them before you call the repair man.check on the web. for locations of fuses,hope this helps
SOURCE: sharp carousel II microwave/convection oven
Hello, I just purchased a Sharp Carousell II convection microwave oven, also built in 1990, serial number 212806. I think the model number is R18244, but part of it is worn off. Can anyone tell me how to get a manual for it? I have never cooked with a convection oven before.
Thanks
SOURCE: full exact diagram of parts for sharp carousel II convention micr
Unit heat syncs and rotor is not working due to high voltage
Are you saying the turntable quit working?
What is your model number?
