Just changed the inlet valves i now have cold water dispensing, however washer goes through wash drains spins fills tub for rinse and thats it will not agitate will not do it even if i try to move dial mid cycle only place i can get it to somewhat work is the rinse on the delicate cycle and theres still a little water left in the clothes.
SOURCE: Whirlpool Washer LSR8233EQO
either motor faulty or if mtor is running then the flexibla coupling between the gearbox and the motor is faulty. Regards Advisor
SOURCE: My whirlpool top loader won't agitate.
Thanks! Removed the fabric softener dispenser, then the plastic cap with the raised plastic strip, inside the post by reaching in and twisting until the o-ring seal becomes free, then removed the bolt using a 7/16" socket with a long extension. Walked in the washer supply store with the whole module that holds the dogs and the man at the counter saw it in my hand, reached under the counter, laid the 4 plastic dogs on the counter without me saying a word and said "that all you need?" think they sell a lot of them? part number fsp-80040. repaired in 40 min.s including the 5 mile trip to the parts store!
Donna K.
SOURCE: Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
