Flashing red indicates internal shutdown due to fault protection.
Only a tech can diagnose the fault (and hopefully repair it).
Good luck with getting it done quickly. :)
Clive.
in the manual there is now screw size specified. there is only a notice about VESA mounts.
here is a link to the manual, so you can have a look yourself:
http://safemanuals.com/user-guide-instructions-owner-manual/THOMSON/32LB130S5-_E
greets, b.
you probably have a fault on the stand by power board. this normally requires soldering and maybe some componet changes. This is not a job for the unskilled. best carried out by a service engineer(shock hazard) there is a service kit for this available from tvs-services.com 012453925
it sounds like you have an av switching fault . This is on a printed circuit board . This fault and cre should be checked by a competant service engineer
this tv is not a dtv tv you can only watch digital tv if you now have a freeview box this is conected via a scart lead . you select av on the tv remote . or you can watch sky or cable . these are connected the same way .
