Stereo is powered on but no sound from speakers. Everything works fine on the display, even the microphone for hands free calling,but no sound. I don't see the reset button described for the 2011 Elantra. Could they have eliminated that or moved it?
What you need to do is pull the fuse panel off! Secondly turn your car on! Thirdly, pull the fuse out for a minute! Fourthly, put the fuse back and push the power button and it will fix the problem! Don't forget to put the fuse panel back on! You will however have to reset all your radio stations! You can also put a paper clip in the reset hole top left of nav screen. Hope this helps you!
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
There is a reset button on the to the left of the phone button on top of the navigation LCD
It is above the FM/AM button. If you don't have navigation then I am unsure where it is. If you have the navigation you can hit Setup, then Main, then System Info, Factory Defaults, then choose settings or memory points but your best reset is the tiny gray button next to the phone button above the FM/AM button right below the XM symbol and Bluetooth word and emblem. It's tiny but directly under the XM logo!
OK, I found a solution myself so I'll share it with you. I disconnected the negative terminal of the battery for a few minutes, which effectively reset everything, even the clock.. It worked though, so if anyone else has the same problem, this should work.
worked like a charm thank you
