Epson Workforce Pro Wp-4540 All-in-one Printer W/inks brand New Logo
Posted on Feb 02, 2013
Epson WP-4540 jam - Epson Workforce Pro Wp-4540 All-in-one Printer W/inks brand New
1helpful
The 4540 will not print after it says an ink cartridge is empty. How can I make the printer print more pages without changing the cartridge?
probably cannot do this as printing with out ink can damage the printer head if the cartridge is empty , it is empty so replace the cartridge and reset it
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Communication error message occurred during transmission. upper cornr has error code b52
This sounds like a fax error, such as the phone line dropped, the remote system hung up. or something like that.
Wp 4540 leaking ink
Possibly leaking from the collection tank in the bottom of the printer, they can only take so much then leak, you can try to remove it and empty it if you can get to it.
Or you may be wiser to try and soak it up with kitchen paper towel, you will need a fair bit to soak it up!
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Yellow leak problem, Any solution?
Unfortunately this is a known issue with these printers and caused by faulty printer manufacture.
You can see what I mean if you do a search on Youtube to find videos like this:
http://www.youtube.com/watch?v=OIVNTMt0ua8
The only solution is to contact Epson and get a replacement, assuming they'll honour their responsibility.
1helpful
How to reset epson t 60 printer
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
How reset E-91 ( wast ink ) ( reset tool ) on epson stylus rx 520
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
