1982 chevrolet S10 Only headlights come one with
Voltage for the tail lamps shows to be a brown wire. Use a test light, check that wire for voltage, headlamp switch on. If voltage then check black ground wire.
A problem with grounds will cause some weird things to happen. Ground wires are black. You can use a test light to check ground, one end of testlight comes from battery voltage, the other end you touch ground, black wire, you have to penetrate the insulation. If the lite comes on, at least the ground is good enough for the test light.
At the moment, I don't care about the maker lamps. I do care about tail--stop--turn--tag lamp. In the past, I have been stopped because of no tag light.
Just my opinion.https://s9.postimg.org/af5e5kqtb/tail_lamps.jpg
Click on the link, hope you can read it.
