Question about Sony FD Trinitron KD-34XBR960 34" TV
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
I HAVE A 42 INCH TV SONY. IT WAS WORKING FINE 2 DAYS AGO, NOW WHEN I TRY TO TURN IT ON THE STANDBY LIGHT STARTS BLINKING AND I GET NO PICTURE OR SOUND. I TRIED TURNING THE WHOLE THING OFF ( DVD/CABLE BOX) BUT STILL THE SAME PROBLEM :( HELP! THANK YOU
  • 132 Answers
Just try unplugging it for a little bit and see how that works.
Posted on Feb 01, 2009
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Problem with tv turning on and off
Does the green light begin to flash when the picture disappears? If so, you have a weak lamp causing your TV to shutdown the picture. Replace the lamp with an original Sony lamp as the aftermarket lamps are known to have problems such as early failure and low brightness. Please be sure to rate this solution. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv will shut off while viewing. standby light flashes.
The problem with your Sony. This is a common problem with these Sony sets.
1. How many times does the light blink? Is it consistent and continuous?
2. Does anything happen to the picture itself, or does the set just turn off?
Answer that and I can help you.
Nov 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
T.V. won't turn on
PCB repair should be done by a qualified tech. Your problem could be HV cap bad,xformer defective or bad connection problems and pico fuse open. Check 2KV cap near xformer.
Sep 26, 2007 | Sony KP-51WS520 51" Rear Projection...
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
494 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
