GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Feb 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power to GE Spacemaker Microwave
The power to my GE Spacemaker Microwave Model JVM 140-JVM142 cut out just as I finished a 30 second reheat. I checked power to the outlet where the microwave is plugged and it is OK. However, I get no lights, no touchpad, no fan etc. Any help? Thanks! Larry
  • 1 more comment
  • quiensabe Feb 01, 2009
    In addition to my post for the GE Mocel JVM 14--142, I replaced the 15 amp ceramic fuse and got power and lights but it blew againas soon as I tried to cook. I guess the Magnetron tube has reached the end of it's life.
  • quiensabe Feb 04, 2009
    To TechCrazy: Appreciate your comments and help!
  • quiensabe Feb 09, 2009
    Thankis techcrazy. I appreciate your help! In review ing the costs and the age of the unit, I decided to replace it. Best wishes!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1116
Points
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Richard Beck
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jun 12, 2013
Richard Beck
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
13986
Points
23
Check this out first before you buy any new parts.
The mag's little cooling fan probably broke loose and fell off the fan motor's shaft. The fan motor will still be running when you hit start but there is no fan on it. The fan keeps the mag cooler. The mag will heat up too much and then shortly the oven automatically shuts everything down when the mag gets too hot because the fan blade is just lying in there, Fan needs to be glued back on the shaft after the shaft is roughed up a little. Disconnect the plug-in wires (note where they go on), wiggle and remove the fan motor from the oven. I used contact cement to hold the fan to the shaft. the fan motor is located right behind the control panel. You have to first remove the grill, then the control panel's screws. It's not difficult to repair. No new parts needed.
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on Feb 02, 2009
Anonymous
Expert
Level 2:
Answers
72
Questions
0
Helped
18860
Points
178
Hi this is tech crazy
the solution to the problem is as follows
Possible causes:
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
  • Anonymous Feb 09, 2009
    Hi this is techcrazy
    sorry for pretty late reply.
    after weighin the pros and cons.I find its better you replace the magnetron tube instead going on for other solutions..
    please rate me on this solution
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
4helpful
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Works but no heat
Possibly a blown fuse inside, or a defective magnatron. If you decide to open the unit, please unplug it first!
Geno
Model 140 (new) stopped heating
If that is a new appliance, I would call GE and ask them to give you a new one or get someone to fix it.
This microwave should have one year warranty.
Hope this helps.
4helpful
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
