Nothing is broke or cracked I simply can't get the hinge pin back in it's position. With this problem it will no longer scan and because light is filtering in my copies( if I lay paper on the top plate and pull down the top cover lid) will copy in a light version. This hinge problem has also affected the top (feed tray function?) for copying - will not process and the paper gets jammed. I can see where the hinge pin belongs but can't get it back in the slot or cut out where it popped out of.
SOURCE: X6150 Copy problems
Had exactly the same problem. Solved by turning copier on, then unplugging it for 30 seconds..plug back in...Problem solved.
SOURCE: Lexmark X3350 Printer
Thanks for everyones help, what worked for me is to reinstall the software that came with the printer. Works just fine now.
SOURCE: The scanner cover is closed,
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
SOURCE: Lexmarkx73 Won't feed paper through while printing
my lexmark x73 makes a clicking sound while printing and paper does not feed correctly
The electrical connector to the IACV
can have 2 or 4 pins:-
pins: resistance between pins should about 10 OHMS +/- 3 OHMS. Resistance between either of the pins and the
valve body is greater than 10,000 OHMS
pins: resistance between diagonally positioned pins should be about 20 OHMS
2) Throttle position sensor - Sometimes with ignition off it is possible to reset the TPS by depressing the accelerator fully and releasing quickly. Ignition might be enhanced by depressing the the throttle slowly. If the car cuts out if the accelerator is depressed quickly this is another indicator of a bad TPS. How
to check? The socket for
electrical connection with the TPS has 3 pins, one for 'ground', one for 5
volts 'reference' and a third (generally the middle one) for 'signal' output.
Back probe the signal pin in the connector to the TPS. Attach the positive lead of a voltmeter to
the probe and measure the voltage output as the throttle plate is rotated. If
working correctly the meter should show a voltage consistent with the throttle
position from approximately 1 volt when closed and 5 volts when fully open.
What is looked for is smooth
voltage increase with throttle change.
If there are drop outs in the transition or that there is no transition seen
the TPS is faulty.
3) cam or crank sensor faults -
2 pin socket (magnetic - sine wave output). One pin is 'ground' the other is 'signal'. A voltmeter set to 2 volts AC should measure
a signal in the 0.2 to 2 volts range on the 'signal' pin.
pin socket (Hall effect, magneto - square wave form output). One pin is 'reference' (5volts), one pin is
'ground' and the third pin is 'signal'.
A DC voltage should be detectable in the 0.5 to 1.5 volt range from the
'signal' pin.
It is important that the voltage measurement take place at start up when the engine is cold and again, 20 minutes later, when the engine has fully warmed up to operating temperature. Often the voltage output from faulty sensors declines with temperature rise. I appreciate here that due to a lack of starting in your case it just might be impossible to check the 'warmed up' situation. I hope this helps.
