Use you smartphone rear, after position the remote eye on the camera press any key. If you some blue flashes after every button click it means the remote is functioning. If none , it's faulty
Universal remotes only work when the correct code is entered into it. Some codes for the same make will work other models, but things are either missing or function differently. You need to find the correct code and try the functions using it. If everything is OK then it should be fine, if not try another code.
However the best remote for the job is the original that came with the equipment. Unless you have paid out a lot of money for a universal remote, you might never get the same responses as an original remote.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
You could have fried something through a power surge or a connection came loose. Check all wiring and see if the speakers are connected, try different audio signals to see if that helps
1. Make sure it's connect to "Audio Out" on your DirecTV box.
2. Yes, the blue light should be on while unit is on an received a signal.
3. Check a second set of audio cables, just to be sure.
4. Toggle the Auto On/Off button on the ZVOX remote.
5. Make sure you've turned up the volume via the ZVOX remote.
If all these fail, contact us at zvoxaudio.com.
Tom
Hello and Welcome to FixYa!
You can go for universal remote. If works with all most all the popular softwares available in the market! i have checked it for Samsung. all universal remotes works for the model described.
Best of Luck,
Please Do RATE my solution, If found HELPFUL, Concerned, Waqar.
