Canon PIXMA MP150 All-In-One InkJet Printer Logo
Posted on Feb 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Current Problem on Printer """E5"""
MY Canon MP145 printer had a fat a'hole problem when i tried to photostat my office work. I followed the previous instructions from the last user i looked it up...
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
but somehow it doesn't seem to work...
please help me solve this problem A.S.A.P.
thank you
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 25, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813568
Points
14613
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
  • daruff123 Sep 02, 2011
    There is no resume button on a MP150, you copied this off the net and I saw this article it is for another cannon printer and it does not work on this model you big dummy.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7317
Points
This works on MP460
http://forums.majorgeeks.com/showthread.php?t=164622
1 Related Answer
Chee Seng
  • 284 Answers
  • Posted on May 28, 2010
SOURCE: canon printer pixma mp150 error codes E5 and E8
Insert with original cartridges will solve out your problem
3helpful
2answers
E5 mp145
E5 is "The ink cartridges is not install or a non supported ink"
Probably one from your cartridges is defective.
23helpful
4answers
My canon pixma MP145 showed E5 and wont print anymore
I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
38helpful
3answers
3answers
My canon mp145 shows E5 when i switch it on
You can try see if this helps
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    26helpful
    3answers
    2helpful
    its ur printer cardige error its has been short or damged frist u have try remove your printer cadrige & reinsert it if problem occer then change the cardige then try to on your printer
    i hope its help u
    Canon pixma error code
    TOLONG DONG CARA RESET CANON mp145 ERROR CODE E5
    old marine
    old marine
    ZJ Limited
    ZJ Limited
