AEG MC143EUX 750 Watts Microwave Oven Logo
Polle Posted on Feb 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave gives one click but it doesn't start cooking. A red light besides the WATT button however lights up.
Level 3:
  • AEG Master 17,130 Answers
  • Posted on Feb 01, 2013
AEG Master
Level 3:
Answers
17130
Questions
0
Helped
3633070
Points
52372
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 28, 2008
SOURCE: Hi. I pressed the 'quickstart'
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
2answers
Microwave has power but will not program or start. Screen shows mem on display
how old is ur microwave ?
most probably its dead, if warranty available take it to the authorized repair center.
Hi I Have a AEG KB9810E microwave/oven combo. Its 6 years old. While the microwave was in operation, the circuit tripped and my partner heard a popping sound. Now its not clear of the AEG tripped the...
Normally when no power coming on from the microwave the fuse has blown in the microwave due to a short hi voltage diode con bad located by the capacitor or micro switches located by the door clips. If you have no electrical experience do not temp to fix it yourself due to high voltage stored in the capacitor.
1helpful
Display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
6helpful
2answers
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
2helpful
4answers
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
1helpful
Kenmore Microwave Turns itself on randomly
22 years old and you are complaining that it starts andomly, you got way more than your moneys worth for heavens sake loosen up and buy a new one. Help the economy out.
GE JES1456WFC001 microwave oven turns on by itself
You are correct. The keypad is failing.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, assuming we can get the part for this Canadian model.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwwave
Could you be more specific as to what it's doing and not doing and when? Thanks.
Top AEG Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
