Unplug, remove battery, plug in, reboot. Is the Network Wired or Wireless? If wireless, connect a Ethernet cable, does it connect? post results. Verify the Network Adapter is enabled in Device Manager.
its wireless network...i did all those things bt its not working... :(
So the Network Adapter is Enabled? Yes or No? What OS are you using?
Have you connected a Ethernet Cable to the ISP modem? Yes or No? If yes to both, have you rebooted the ISP modem and wireless device? Checked ALL the cables? reseated the cables? Is there any other device connected to the wireless? Is it listed in software on the laptop Available Wireless Networks?
yes its enabled...OS is widows 7
i ve connected the modem to the notebook bt cant open the page where i can connect or disconnect....now i m using my modem in my pc...its working......there is no other device connected to my device......actually i was working on the notebook and suddenly my modem fell down...after that notebook got hang....thn i restarted and started facing this problem....thnks for ur concern....i think i need to go to the service center tomorrow.... :(
The modem was damaged in the fall?
Let us know the outcome.
modem is not damaged cos i am using my modem in desktop ri8 now......one thing the network adapter is not working.....its showing that " this device is not working properly because windows cannot load the drivers required for this device".... now what can i do?? :(
OK , What is the Model of the Acer Aspire? Win 7 drivers will be easy to find. You could do this, Open Device Manager, Network Adapter, Right click the Network adapter that is showing driver required, Uninstall the adapter, reboot the laptop, allow Win 7 to ID the adapter and apply the correct driver, ( your laptop came with Win 7?) , Reboot to apply the driver, do Windows and Acer Updates.
SOURCE: acer aspire one notebook internet problem
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
2433
SOURCE: My acer aspire one mini notebook doesnt connect to internet
This will happen if you let the battery go completely dead. Some files become corrupted.
Solution:- Right click on Settings (preferences some models). Select 'Network' then double click on 'gFTP'. Scroll down to '.gconf' and double click. select and double click on 'system'. Right click on 'Networking'. Scroll down to 'Delete'. Left click on 'Delete'. Confirm 'YES'. Turn off the computer, then restart. What you have done now forces the computer to re-create the networking file. Your networking icon should re-appear on the taskbar. Note this is only for LINUX systems. - Good Luck!
SOURCE: i cant get into my internet settings !acer aspire
I know nothing about Linux and had the same problem. I found this on another site as I have been searching for an answer. Just finished as instructed and it has worked. Just in case I renamed the folder rather than deleting it!
"Follow this then restart and everything should come back to normal. It took me 3 minutes and worked fine.
This is to find and delete the networking folder (which is causing the problem):
1. From the regular Aspire One options page, go to the Files panel
2. Click on the triangle to see more icons
3. Click on MyFiles, which opens a file manager window.
4. In the menu bar, select View->Hidden files, to show a tick in the box. You should be in the "My Disk:///" directory.
5. Scroll down until you find folder "gconf" and then click on that
6. Find folder "system" and click on that
7. You should now see folder "networking" listed as one of the folders.
8. DELETE IT! (Right click on the networking folder, and select option delete.)
I just restarted from here and the icon re appeared in bottom right the menu bar, I just clicked on it to set it up with my wifi signal and it did the rest itself. "
Have fun and dont panic!
SOURCE: cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
SOURCE: Cant access internet through wireless network.
if it flashes orange it is trying to connect and detect the internet, if you are connected to your wireless router but no internet check the security keys on the router and the laptop if they are the same, I guess you get the error limited connectivity, and if possible check for programs that could cause your wireless to not get the internet but get connected to the router, check for network magic uninstall the program from your system restart the computer try connecting again.
worst case that can happen is you can try uninstalling the wireless drivers and reinstalling it if the wireless devices gets an error during installation of the driver then you will need to replace your wireless card in your laptop, orange flashing in router meaning it does not detect internet from the modem ^_^
one of my bro solved my prb...now its working n i can use internet on my notebook...tnku for the support...ve a nice day,,, :)
