Microwave Ovens Logo
Anonymous Posted on Jan 31, 2013
Setting level power of microwafe samsung - Microwave Ovens
Level 3:
  • Microwave Ovens Master 17,130 Answers
  • Posted on Jan 31, 2013
Level 3:
Answers
17130
Questions
0
Helped
3635231
Points
52372
You can either choose to select the SET levels for the heat which can be a direct button or you can select the power button and scroll up or down the settings. Also the weight of the food must be chosen to be effective for the heat.
Click on Microwave
Samsung Microwave power level - no button
As you didn't specify any specific model, one of the Samsung models uses this scheme to change power levels.
You begin by pressing the "Microwave" button once. Pressing it again will display different power levels, from low to high.
How do i change the power setting on a Sharp carousel microwave
Which model of Sharp microwave do you have?
For the SMC1441CB, after setting the cook time, press the power level button and then the appropriate digits for the percentage of full power to use. For full power, press power level then 1 and then 0. For 50% power, press power level then press 5.
For the SMC0710BB, after setting the cook time, press the Power button until you see the desired power level displayed on the LCD screen. Press Power once to get 100% power. Press Power 6 times to get 50% power.
For the R-659YW, you set the power before setting the cooking time. You press the Power button several times to get to the desired power level. Pressing Power 7 times will have the microwave cook with 40% of its full power level.
Many current Sharp appliance manuals are available on their product page or the Sharp support page. The current Sharp microwaves are listed here: http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models.aspx?facet:configurationfilter=Countertop . Other appliance manuals are available when you enter the model number in the search bar at http://www.sharpusa.com/Support.aspx .
I hope this helps.
Where I can buy a fuse (high voltage)for my Goldstar microwafe ovens model MA400200?
You have to know the exact fuse model and specifications then try this link: eBayeBay
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Everything works fine, except my food is still cold
Check the "power" level setting.
Most microwaves allow adjusting the power level from 1 to 10 (or 10 to 100 on some models). 10 (or 100) is the highest/quickest setting.
I can check mine by entering a time...then before pushing "start"....push the "power" button....and change the level if I want.
1helpful
How to set temperature in Samsung microwave. 160 c means ? watts.
They're totally non-interchangeable as they're two totally different ways of cooking.
There is no correlation at all between a temperature setting used by electric and fan ovens and the microwave power level, there's not even a rule of thumb. For microwave cooking, the fat, sugar and water content of any given food item as well as the mass and shape are what determine cooking times and microwave power levels, and not all foods can be safely microwaved as high fat/sugar content foods may catch fire.
When I turn on it snaps and smells burnt
your plug wire is loose from inside microwafe tighten it.
Power level again
It is probably a 700 watt model. Most ovens have 10 power levels, ranging from 10% to 100%. Normally you press POWER LEVEL, then press 1 for 10%, 2 for 20%, etc., then press START or COOK to cook. We could not find exact information on this model.
Power
You can download some models' owner's manuals here: http://www.samsung.com/support/productsupport/download/index.aspx But the attached diagram shows how power levels are categorized or rated. When you want to cook at a power level other than high, you normally hit POWER then a number from 1-0. On some models you press POWER repeatedly until it shows the power level you want.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
