How to get trans out park when stuck
Chrysler doesn\'t sell this part alone, they sell the whole Shifter Box for over 200 dollars. Autozone sells this piece(park lockout mechanism) and its made from metal, I replaced it on my daughters 300 a few months ago
Procedure is as follows: Just stick a long screwdriver through the square hole just above the shift gear knob, not where the rubber surround is but above that after you take off the silver chrome plate surrounding the shift knob of course. line the screw driver up with the little cable you will see down in there about 3 inches push that to the left and pull your shifter knob to the right YOU NEED TO HAVE YOUR FOOT ON THE BREAK while you do this, if it doesn\'t work its because the spring that is attached snapped the hook off the pink plastic part, try the following
1 Break down that center console!, if you need to move the car immediately to get home or to your garage or shop then its not a problem if you have a few tools, start popping the trim off the shifter assy, pull up and out on the small storage compartment to the right of the shifter, this will uncover a small pink lever (which will get you at least on the road but may not work if this is broken , it was on my daughters car), if it is you need to go deeper! Take out the rubber mat directly under the ash tray and cigarette lighter, this will expose two philips head screws, undo them, move through trim with a flathead and keep prying trim off until you have the shifter assy visible, if your shift knob is giving you problems, try sliding the very bottom chrome plastic trim down then the knob up as you spread the white plastic at the base of the leather.
2 Ok your down to the shifter, now with the key in and the car running press and hold the pink lever on the right side of the shifter, there is also second pink part( this is the cheap piece of junk that has you doing what your doing) on the front of the shifter assy, press this pink part as well and as always with your foot on the brake try to shift, you should be in good shape, now to limp back to your proper repair facility of choice (your house) Shift into drive and only reverse if you need to, when you park leave in neutral and hit the parking brake,
