My whirl pool gold accubake system is in loc mode and what ever i try to do it wontsay eny thing else but loc the timer works on my oven and the micrwave works and so does the stove but the oven wont say eny thing but loc and if i press a button it says (start ?) and beeps a couple of times!!!!!!!!!!!!!!!!!!!!! please help??????
Daddysgirl, You do not indicate the model number or the age of the stove. Early model self clean stoves used a 'oven lock door handle.' Later model stoves do not use such a handle but is electronic. I believe this is the one that you own. You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature? If not... I believe that you have a touchpad control problem. You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning. If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM). It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM. The oven ECM is very expensive ($150-275. retail) plus labor to install. Hopes this helps you! HandyHenry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
