Suddenly my Daewoo microwave displays only ac errors. Start button is no longer working because of this error. Any1 has a solution and a service manual (what 2 replace) Thanks in advance Jenni
Possible that the panel or the processor is a suspect. You can remove the top cover and clean the panel and main board. If there is no result it is best to take a second opinion.
Click on Microwave
SOURCE: microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
If only the start button is inactive but you are able to set timing then then the start button pad must be worn out.
