I have a wrangler Hero watch, I replaced the battery and the Digital part works fine, the analog is not moving, is there another battery? It worked fine before the battery croaked. Any ideas?
SOURCE: Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
SOURCE: I have A wrangler hero watch ,it has digital&
I would suggest that you take a photo of the dial part of the watch and post it to
Mr. Martin Schneck
Omni Watch & Clock Co., LLC.
140 58th Street
Suite #6C
Brooklyn, New York 11220
phone (718) 921-1000
This company appears to be the marketting it and should be able to provide you the instructions.
