The light is out and the fan starts running when I close the door - I can still cook food but would have to leave the door open at all times to stop the fan from running. Should I just replace it??
SOURCE: I have a GE Spacemaker XL1800 over stove does not cook
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: ge xl1800 microwave door close
That's
usually a defective upper or lower door switch (or either switch's
mount may be bad) or a stuck relay or bad electrolytic on the control circuit board.
At
Our file on door switches is here.
After you or a friend look that over, if you still have a problem, we repair these control boards for $39.95 with a one-year guarantee.
Instead of having yours repaired, you can buy a new control circuit board from the Pros here, our favorite supplier.
We're
advice and we'd appreciate your thoughtful rating of our answer.
SOURCE: GE Profile Spacemaker 2.0 Microwave
If
it goes dead or blows the breaker or GFI when you plug it in or open or close
the door, then there's a problem with a door switch or door switch
mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. Other times, it's a broken tab on the switch
holder, allowing the switch to rotate just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
troubleshooting & testing.
We're happy to help you and we'd appreciate your
SOURCE: GE Spacemaker xl1800
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
SOURCE: GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
