SOURCE: I need to move my body solid G4I to another room,
If you have top clearance you can find 1/2' conduit pipe (elec.) cut 4' you need three. Put on floor in front of piece lift just enough to place pipe1 under as far as you can to take weight and roll on -place next pipe and so on. Be careful of you fingers! You can steer it if you get good at it.
GOOD LUCK BRUCE
SOURCE: need assembly manual Body Solid PSM1442XS
Here is the body solid website you can access manual that you need
http://bodysolid.com/Support/Assembly_Manuals.cfm
first disassemble the chest press then tie wrap the cable to frame. pull the weight stack off then tie wrap weight stack cable then remove rear base all away to where the front seat is attached now you should be maneuver to the other room
SOURCE: assembly and/or parts manual for Body Solid EXM-3600 and EXM-1950
The EXM 1950S Is the G4I and EXM 3600 beats the heck out me!!! The best suggestion is to call Body-Solid Directly if you have spent alot of time researching you may have gotten the answer from them pronto.
Call Them @ TECHNICAL SUPPORTAvailable M-F 9:00am to 5:00pm CST
Toll Free - 800-556-3113
Fax - 708-427-3598
or [email protected]
