Printer error says paper jam, however it is the printer ink cartriage carrier that is stuck and will not slide to left to print. how to fix
SOURCE: HP C3180 all in one printer won't realign
We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
Best regards,
Rosener Guyano
SOURCE: carrier jam
your encoder strip(a transprent strip behind the carriage) is either broken or loosed up and so it is not able to get self aligned.kindly fit the encoder properly or change the encoder if neccessary.encoders are usually very cheap.wish u luck!!
SOURCE: Error 336
hmmm...ok...then it appears that your drivers are shot..you know how to remove them, from PC, download new ones, and re install?
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
If you have cleared off the paper jammed within then it is possible that errors have crept into the drivers. sometimes the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
