I have a GE gss22wgpa side by side and the freezer and refrigerator are not freezing or cooling completely. I emptied the freezer and there is ice on the back walls.
The defrost heater could be bad and the coils are freezing. The defrost sw could be bad.
Let it defrost for awhile. Hook it back up, After on for a bit, check the fan under the fridge to see if it works. Also is there any air blowing inside the fridge and freezer. If not then the cooling fan has gone bad. Thats easy to replace. If none of the above then eather the compressor is going out but doubtful being there is ice on the back. But the freon could be low.
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
