SOURCE: my sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
SOURCE: sony grand wega master reset
In my openion, Highly Qualified Sony technician will do this job properly because your TV needs modification in C2 Board.
SOURCE: sony kdf 50e2000 fans not working now: read below...
hi, Why did you change the thermal fuse - specify the original problem, where the fans working before and need the correct model number before I can help you.
Model kdfe2000 is not listed anywhere.
SOURCE: sony kdf-50E2000
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
