Onkyo TX-SR606 Receiver Logo
Posted on Jan 31, 2009
Kube 2 subwoofer hum
I have the Onkyo TX SR606 set up with the Kef 2005.3 speaker system which includes the new kube 2 subwoofer. When switched on and the subwoofer's led is on red, no hum is heard. When any film starts and the kube 2 turns on with the led green, this is when the annoying hum starts. We contacted Kef and they sent out another kube 2, and to my surprise this does the same. What i did find out is, that when i pull the Qed subwoofer cable out half way from the receiver the hum goes away and the green led light is on, but then i dont get any of the low frequency sounds which the subwoofer is ment to give you.
Please help.
  • 1 more comment
  • Anonymous Feb 01, 2009
    Hi, I have exactly the same problem. Brand new Kef Kube 2 makes an annoying hum when it goes as soon as it's operational. i.e. red LED turns to green.
    Totally unacceptable, even for a cheap system, let alone this expensive one.
    Be glad to hear of any solutions, before I send this system back which is a shame as I like the satelites!
  • Anonymous Feb 23, 2009
    I have the same equipment set up Onkyo SR606 and Kef 2005.3 speakers. The annoying hum pervades the room and once heard is difficult to ignore. I have tried re-arranging all my cables to separate power from audio etc to no avail. All my system (including hi-fi) is through a 10 way surge protected pillar. I have tried separating the systems into 2 supplies but this has had little effect. I started to notice the hum after I had installed a new TV but disconnecting the TV totally does not make any difference so I suspect the noise was there before.
  • Anonymous May 18, 2009
    Same, ish...Onkyo 606, Super Cube 3 Sub - loud hum. With all leads disconnected from the sub and the AVR off - hum? Could this still be a ground problem if the sub is the only thing powered on? I took it back today and got a new one, it hums....
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3609
Points
7
The Kube Sub-woofer is earthed via its 3 pin plug. The Onkyo and other components I have in my system are not (they are double insulated). During normal operation, a difference in electrical potential can exist between these components in the system. I found that this potential was finding a path to earth via the audio cable and on through the subwoofer's earth. The path was via the earth portion of the audio cable and so gave the hum irrespective of volume levels set either on the Onkyo or the sub.
The fix is to ground the Onkyo to the sub. I used a length of electrical cable between a panel mounting screw on the back of the sub and a screw on the casing at the rear of the Onkyo. Try it out with a piece of cable manually touching screws with the bare ends of the cable until you find ones that give continuity( the hum will go immediately). I then crimped a small fork end electrical fitting onto each end of the cable which can be slid under the slighly loosened screw head and resecured. All I hear now is the fan on the Blu-Ray player!
  • 1 more comment
  • Graham Parsons Oct 02, 2013
    Thankyou, Thankyou, Thankyou. I did as you suggested and it was like magic it worked straight away. I've been messing around trying to sort this out for ages. Much appreciated.
  • Antony Formisano
    Antony Formisano Feb 09, 2019
    Yes, thanks - fixed the problem for me, though why it started after I've had he Amp and SW together for at least 4 years is a bit of a mystery (I tried different SW cables)
  • Anonymous Mar 20, 2019
    Thank you for this I was ready to throw my sub out of the window. As my sub is some distance from my amp, I grounded it through one of the speaker terminals which creates the ground as you suggest. Although the humming started after I bought a new TV and hadn't been there before, unplugging everything did not work, but with your method the humming stopped immediately, what a relief :)
Richard Smith
Level 1:
New Friend:
  • Posted on Jul 09, 2017
Richard Smith
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3609
Points
Found that the source of the hum on our system was the Sky+ HD box.
This was solved by connecting an insulated wire from a screw on the back plate of the Sky box to a screw on the back plate of the Kube.
Upgrading to a SkyQ box shortly and expecting to be able to do away with the wire.
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Feb 05, 2009
Anonymous
Contributor
Level 1:
Answers
27
Questions
0
Helped
19601
Points
70
You have a ground loop. That is, the grounds of your reciever amp and subwoofer amp are meeting up at more than one point. They should only be joined by the cable betwwen receiver and sub. Here are some things you can try...
- Be sure all of your accesories (including any connected video) are plugged into the same outlet. Of course you will need to use an outlet strip (preferably a surge protector) to do this. This will join all your electrical grounds at one point.
- Use a "cheater" plug. These are the ones that convert a three-wire outlet to a two-wire by removing the ground. Use it on the power plug going to the Kube. This will break any ground loop between those components.
- Temporarily disconnect your TV cable or sat dish. Sometimes the ground there causes strange things to happen. If that cures it, you will need a cable transformer.
Good luck !
Marco
1helpful
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Im having trouble with connections from kef psw 1000 sub to onkyo tx sr506 amp. sub is making a bit of a humming noise but not getting any proper sound through. dont know what im doing wrong. can anyone...
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
No sound with the tx-sr606
This is a problem of DSP. If enter service mode,
You will see a picture like this. You can do nothing
Except selling this amp cheaply. This DSP ??????
Causes NO SOUND in all channels. Besides, never
Buy 2nd hand onkyo from 5/6/7/805 to 5/6/7/848Series amps. You will suffer the consequences!!!!
dsp problem-cul4vjmzkuvncverhuthjcbk-4-0.jpgdsp-1-uogyjvcdpkwkvogd1g1ztygl-3-2.jpgdsp1-uogyjvcdpkwkvogd1g1ztygl-3-3.jpg
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Center channel audio distortion and noise
I have similar problem with my Onkyo Tx-SR600. It only happens when it's in surround mode. When switch to Stereo or Direct, the scratchiness go away. Still trying to find a solution to this problem.
Sorry this is not a solution.
I am having virtually the same problem and I wanted to find out if you managed to fix the issue?
It seems to be my LCD causing the static noise (even when it is powered down). The static noise goes away when I physically unplug the TV or disconnect the HDMI cable to the amp.
Mark
Onkyo TX-SR606 bass treble settings seem to make no difference
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
2helpful
4answers
No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
1helpful
2answers
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
