SOURCE: Need drivers for EC372S dvb tv tuner but not
you just need to download this freeware... unknown device identifier.. it will automatically find the driver that you need.
SOURCE: Hi, Ihave 2 questions: Is the
the card will work in your hp if you have the expresscard slot on either side of the laptop, take a peak in the slot - remove the plastic holded from it, look at the shape of this card, if the slot matches then yes.
if you don't like that answer and would like a more solid one, post me the exact model number of your DV2500 SERIES laptop. model example: DV2599EHGFDA
this tv tuner uses NTSC for analog tv and ATSC+ for digital TV.
NTSC is used mainly in the united states and australia uses PAL format.
so most likely this card would not work in australia, unless you know there is digital ATSC+ format available.
