I NEED TO REPAIR/REPLACE KEYBOARD DUE TO A STICKING KEYS PROBLEM
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
SOURCE: laptop advent 9517
Try http://www1.medion.de/downloads/?lang=uk
and also
http://www.ecs.com.tw/ECSWeb/Downloads/Category_Download.aspx?Categoryid=3&MenuID=37&LanID=9
this has most of the advent drivers
SOURCE: replacing keyboard for advent 7108 laptop
I have had the same problem several times over and it is VERY likely that the liquid has reached other components (specifically the motherboard) and will corrode anything that the liquid has come to rest on. The keyboard itself is easy enough to remove and replace, but the only place I am finding parts for advents is in the UK. This means replacement of the keyboard COULD be costly and in the long run the computer may fail due to corrosion especially if it was pop or juice or any other acidic liquid.
Here is the link I found for a possible solution.
http:/www.adventspares.co.uk
if they dont have it, these guys might...
http://www.techno-mart.co.uk/advent.html
Good luck, and I hope you havent damaged your motherboard!
Kirk
SOURCE: How to replace an Advent 7000 keyboard?
disassemble your keybr from laptop n using a tweezers to remove old pin n reassemble new pin. using it tool press new pin until "klik" sound.
SOURCE: Need to replace keyboard on acer travelmate 8204 laptop
you have to unscrew the part that contents the power botton then unscrew the keyboard it easy goodluck
