Runs...no heat
SOURCE: dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
Gas Whirlpool Style Version 2
Gas Maytag Style
Gas GE Style
Electric Whirlpool Style Version 1
Electric Whirlpool Style Version 2
Electric Maytag Style
Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
SOURCE: dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor. Check to see if heating element is OK.
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
SOURCE: I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
