SOURCE: vertical thin linings on lcd monitor
It is due to immense use of your laptop. So dont worry, off it for some time and on it again. It will not come. It is the same problem i m facing with my laptop. All the best.
try going into bios if u have same problem in bios then problem with ram try reseating ram if thereis same problem then send the laptop in 4 repair
SOURCE: Vertical line on LCD screen
yea thats the same with my insignia 20" moniter it has a greenish blue aqua line (very thin) and its right at the top of my screen it must be crack though, so ill return it back to costco. goodluck ps it is cracked =|
SOURCE: vertical line off centre of monitor
Likely a crack in your cable - try a new cable if possible (or borrow one) - other than that its likely a fault in your monitor.
SOURCE: green vertical line on desktop near right side of monitor
Have you tried to change your wallpaper ?
