Need lid for 2 cup rice cooker
SOURCE: farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
SOURCE: I lost the measuring cup for the cooker
I always fill rice up to the 2 line and then add water up to the 3 line.
SOURCE: Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
SOURCE: Rival 6 cup Rice Cooker Instructions
you should have a "lever: you push down to cook and it will "pop" up when the rice is finshed, your cooker holds 6 Cups cooked rice, use 2 cups medium grain rice/ 3 cups water this should yeild you 6 cups of cooked rice, let sit about 4 min after the lever pops up to allow rice to finish steaming
SOURCE: Rice cooker lid replacement?
if you still have the reciept the best thing that i would suggest is to take it back to the store or call the manufacturer and they will send you out another under warranty cause there should be a 1 year warranty on the unit.
