Have an onga js120 attached to a tank feeding my in lawn sprinklers. The pump hooked to an automatic timer has stopped working. When i release the valve nothing happens until i hit the restart button. it like it is not keeping pressure and when the valve opens it is not kicking in as there is no pressure lost. On manual it completes a complete cycle of all stations and may work for another day or two or may not work again until you hit restart.
I assume the pump runs when switched on until a preset pressure is reached in the outlet when it cuts off, remaining on standby until the pressure falls due to a demand for water when it automatically restarts.
To achieve that automatic function there must be a pressure switch in the outlet side of the pump and that or the associated circuitry is where the fault must be as the pump seems to run ok when reset is pressed.
If it is modern it is likely electronics are involved and it would seem more likely those are at fault than a faulty pressure switch which could be expected to remain faulty all the time.
Another possibility is the motor is overheating due to a fault or due to the duty cycle being exceeded and the safety cut-out must be manually reset.
