Replacing and configuring a main power board to a Plasma display is not a simple job as you thinks. With only a multimeter, you can't do anything. It is a skilled work. Contact any experienced service technician. If you wish to get more details about the repair process of plasma displays, check this link. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
hmm sometimes the responses are questionable been around the voltage and industry for 25 years any way can you help me any futher I was looking at Q406 rjk5020 i tested in circuirt
I tested Q406 in circuit with a Volt/Ohm meter it showed a short to ground on all three legs but like i said in my previous post it did not blow the fuses until i plug in that last board couild this be the problem thanks
Hello still looking for some input on this panasonic TH-50Px80u tv q406 (rjk5020) did show short in circuit all three legs showed short to ground shop jimmy got $85.00 on this power supply is this the best way to repair or to find this transistor and fuse and replace or is this power supply not the problem is there a way to check or test this power supply
Q406 (rjk5020) was shorted it only blew the fuses when the boards were all pluged in I tested in circuit and it checked short I remove it still shorted went to ebay oredered athe repair kit for $10.93 which included the fuses and the transitors and install and tv worked great do be careful of the voltages on this board know what you are doing soldering and testing go luck
