Gone through all the steps, when I push the machine icon to sew, I keep getting the message "raise the presser foot". Last week the machine was working fine. I have shut the machine down disconnected the embroidery attachment T basically started from step one with the same results....help
There are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
SOURCE: Pfaff triptronic 2040 sewing machine
Could be a couple of things:
Hope this helps.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
SOURCE: How do I remove the face plates on a Pfaff
The plate is not screwed in, it is held tight by a couple of metal springs on each side. Just take a small regular screw driver and gently pry up the face plate. You may have the presser foot lowered by the switch on the right side of the bobbin/shuttle area slide it so the presser feet raise.
SOURCE: Pfaff Creative 1371
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learn the repair skills!
Good luck.
SOURCE: When i switched on the Pfaff 2170, the message
once you switch on your sewing machine.the machine initializes all moving parts motors and sensors once initialization failed or one sensor is broken/cover with dust the machine will not work a message will appear instead..like sensor 6 not found...you need to locate this sensor..
This is a 7570 machine
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embrodery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
