SOURCE: front panel connectors
hi im wesley. ok the power and audio connecters is very simple if you look at the bottom right of the motherboard you will see you can plud them and it says the name of witch is the power and witch is audio and it doesnt realy make a difference witch way you put them in just as long as they are on the right pins. the usb might be a little more tricky unless it says witch connecter is the usb 1&2 then its the same as the power led but if you dont come right i will try to get a diagram for you or draw one up but it might not be as accurate tho as i do not own a asus motherboard but i will do my best.
SOURCE: where do i connect the front panel MIC connectors in the motherboard
1 2
3 4
5 6
7 8
9 10
Pins 5 and 6 , 6 is ground.
SOURCE: need connection diagram for awrdacpi motherboard
I need front panel connection diagram for awrdacpi motherboard
SOURCE: Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
SOURCE: Hello! I need help: how to connect on board mic
You can get the intsallation guide from Asus themselves.
Click in the link below or copy and paste it into the address bar of your browser. When the page loads click on manuals and select the Multilanguages guide to download it to your computer.
Link below >>>>
http://support.asus.com/download/download_item_dna.aspx?product=1&model=P5GC-MX/1333&f_type=12&SLanguage=en-us&os=17#f_type_12
Regards.
