HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch Logo
A
Anonymous Posted on Jan 28, 2013
IpAddrMgr: Unable to learn HW IP host routes, table FULL
What Is the Meaning of Each Field in the display ip routing-table verbose Command Output?
Are you referring to something like this?
IPv4 Route Table =========================================================================== Active Routes: Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.2 25 127.0.0.0 255.0.0.0 On-link 127.0.0.1 306 127.0.0.1 255.255.255.255 On-link 127.0.0.1 306 127.255.255.255 255.255.255.255 On-link 127.0.0.1 306 192.168.1.0 255.255.255.0 On-link 192.168.1.2 281 192.168.1.2 255.255.255.255 On-link 192.168.1.2 281 192.168.1.255 255.255.255.255 On-link 192.168.1.2 281 224.0.0.0 240.0.0.0 On-link 127.0.0.1 306 224.0.0.0 240.0.0.0 On-link 192.168.1.2 281 255.255.255.255 255.255.255.255 On-link 127.0.0.1 306 255.255.255.255 255.255.255.255 On-link 192.168.1.2 281 =========================================================================== Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 192.168.1.2 0.0.0.0 255.255.255.255 UH 0 0 0 eth1 10.10.10.1 0.0.0.0 255.255.255.192 U 0 0 0 eth0 192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1 10.0.0.0 10.14.42.129 255.0.0.0 UG 0 0 0 eth0 0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth1
1helpful
What is the meaning of IP
IP Address stands for internet protocol...its a kind of internet communication protocol.....
The Internet Protocol is responsible for addressing hosts and routing datagrams from a source host to the destination host across one or more IP networks.
it having two types
1>static ip address(which is used by any hosting company)
2>dynamic ip address(which we genrally uses)
and it having two version
1.IP V4
2.IP V6.
i think its enough if you want to know more about it then feel free to contact........thnks blacktulips
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
2answers
Client can not surf or ping specific web address - Cisco router
I am not sure but I believe the IP address is not correct. The trace goes to the following address:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Tracing route to 200-100-1-5.dsl.telesp.net.br [200.100.1.5]
on my machine. This is only a service provider I believe and not an end website. Have you checked and verified the ip address with the contact organization? Just because you can run a trace route on an ip address does not make accessible.
The cisco could also be blocking the outbound connection at your end.
Hope this helps.
Can,t connect to internet
If you have a signal, this often means that you have no hosts in the host routing table.
Go to Options -> Advanced Options -> Host Routing Table.
Click the Blackberry key to bring up the menu.
Choose "Register Now".
Adsl connection
The error Destination not reachable is due to a router not having a route in its routing table; to fix it I suggest consulting your documentation and/or using the admin console and its built-in help to add the route you need to its table. Note that 192.1.1.x is unreachable from 192.1.2.x LAN segment. Not familiar with Paradyne routing syntax, so I would try their web site if available for full details. If you can be more specific about the IP addresses (subnets, they're called) in question, I can provide more info. as to how its done.
1helpful
2answers
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
2helpful
2answers
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Hurricane h5200 modem/router
Hello jmazaredo,
Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
In other words edit your hosts tables (hosts file) with the entry (Example 1):
IPADDRESS FQDN ALIAS
192.168.10.2 somesystem.myhome.com. system
192.168.10.5 somesystem2.myhome.com. system2
This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
Once this is done if it works then try this setup:
1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
I hope this helps.
Thank you,
Shuttle83
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
