I need to buy the base stand pedestal that can hold the tv straight
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
SOURCE: Vertical Flashing Lines on Toshiba 42HP84 Plasma 42"
troubleshooting PCB's of certain electronic units require advanced technical skills. no service manual of any source would provide specific solutions. the best you can get are schematic diagrams. if your field of expertise is not related to electronics, i suggest you let the technicians handle the problem for you. every shop have their repair cost qoutations. just be sure to ask for warranty of their repair. goodluck!
SOURCE: I need a pedestal stand for my Toshiba 42RV530U.
Manufacturer Toshiba Part Number 75010935 Description BASE BASE ASSY, BASE
SOURCE: 42hp84 toshiba plasma
One of the fuse proballly broken in Board Z- sus due to short cicuit inside the single IC (STK 795-***) hidden under a single heat sink. This big IC was hard to remove.Be gentle when removing the 2 flexiboard.................Tarogo
SOURCE: I have a 42" Toshiba Theatre Wide Plasma tv, model
I'm not sure I completely understand your description of what you see. Do you have any audio and video of channels?
You could start by checking your different settings. Your inputs settings and display settings. You could be in a demo mode or in a calibration mode if you are seeing color bars colors (white, black, cyan, magenta, yellow).
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
toshiba don't have it any longer
