Unfortunately I realized that the sound disappeared totally .I mention that the option A.V.L.S. is not on ( I know how to use it ) The Walkman is displaying the song like playing but there is no sound and also if I try to adjust the sound level nothing happens . I made already a reset from the 'hidden" switch on the bottom. What can be the problem ?
SOURCE: Sony Walkman NWZ S616F Frozen dead at "Every moment has its music
Find a needle and press the reset button at the bottom by it.I havesolved thesame problem by this way.
SOURCE: remove write protection on a walkman nwz-s616f
I had the same problem after using this product for a month, suddenly it showed the warning of write protection.
I even contacted the sony customer center but to no avail. their answer was of no help at all.
so here is what i did to make it work:
1) First install "QuickTime version 7.2" or later (you can download it from torrent if you are unable to register it, i.e. with a crack)
2) Then install "Windows Media Player 11 " (you can download it from torrent if you are unable to validate it, i.e. if WinXP not original)
3) Now install "Media Manager for WALKMAN" (a compatible software provided by the sony company to interact or communicate with the walkman), freely available for you to download at sony's website.
After the installation, connect the walkman to your computer. Now it should easily add or delete data from you walkman using this software or without it as well.
SOURCE: Sony Walkman Video NWZ-S616F MP3 Player, low
go into music settings and go to volume limit and turn it off or it might be the headphones or if it goes up to 30 thats the limit its supposed to go up to.
SOURCE: Describe your Sony Walkman Video NWZ-S616F MP3
Hold the reset button on the back and it will rebot and should work.
SOURCE: can't play back video on sony walkman nwz-s616F
Hi everyone, I had this problem with the Sony MP3 players I bought for my kids (NWZ-S615F). There's a new (free) video converter from iWisoft (download.cnet.com or easy-video-converter.com) which does the trick. I looked into the others mentioned here and there were some virus/trojan horse concerns but so far this one seems fine. I downloaded the file, then did a virus scan, then ran the application and did another virus scan. I've used it 10-15 times since then and did another virus scan and nothing comes up so looks good. Choose the output file format as the first option under iPod. If it hangs while doing the conversion, try to run the output file before you get frustrated - I've found that most of the time the conversion was completed before it hung and the video plays fine.
