That's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
most modern tvs have vga connector for doing just that look at the back of the tv should be one there. If not then look for what is called a Svideo socket will be a small circle plug with about 5 pins and dont forget to put the tv mode to its respective setting ie P.C or Svideo/ AV1
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Try hooking the xbox up to another tv to see if you get color. If you do it isn't your xbox. If you dont then it's your video cables going bad.
Hook a dvd player into the same spot you had the 360 in on your LCD see if you get color. If you dont then its your TV, if you do then it's your xbox video cables going bad.
