Televison & Video Logo
Posted on Jan 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coloring is off and there is a ghosting effect
Hello, I posted this issue about my Samsung 42" rear projection HDTV (Samsung HCN4226W.). Your solution sounds good but I have one question, the part number you listed was:
BP95-00142E convergence amp
When I do a search on that, the part number comes up as a convergance board. There is an amp with part number:
BP94-00155A Amp
It is the amp I need, not the board, correct? Thank you for your help.
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Mar 31, 2009
Anonymous
Expert
Level 2:
Answers
298
Questions
Helped
304245
Points
615
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
1helpful
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
1helpful
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
2answers
Samsung HCN4226WX has green and red ghosts very bad
Probably bad IC's (color or convergence amplifiers). Soldering and knowhow required.
You have a convergence problem.You can replace this module cheaper than it can be repaired.It is so easy to do and electronics skill level is not required.If you can unplug the TV and remove the rear cover,then you can do this repair yourself.1 screw and 5 connections(plug in) is all it takes.The part number you need to order is BP95-00142E convergence amp. I would google search it and find it at the lowest cost to you.Good luck and please rate my information.
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
No power
you can get a replacement deflection board at the following link. If you dont know which one your model requires leave them a email with your model number and what youre needing they respond quickly and will provide the proper one for your model.
http://servicemanuals.vstore.ca/
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
3answers
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
RED Ghost Image on Samsung 42" Rear projection HDTV (Model - HCN4226W)
I WOULD RATHER THINK IT IS ONE OF THE CINVERGENCE AMPLIFIER & DRIVER IC,S A REAR PROJECTION TV NORMALY HAS 2 OF THEM AND THEY ARE THE SAME AND NORMALLY THE NUMBER ON THE IC STARTS WITH "STR *****" SWAPING THE TWO AROUND WOULD PROVE THAT YOU GOT A PROBLEM ON ONE OF THEM,THEN JUST GET 2 NEW IC'C THE SYMPTOM THAT YOU ARE DESCRYBING IS MOST LIKELY THE IC'S HOPE THIS HELPS IGNATIUS ,SOUTH AFRICA TV REPAIR ENGINEER
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
