Konica Minolta bizhub 250 All-In-One Laser Printer Logo
A
Anonymous Posted on Jan 28, 2013
There is no matching paper size - Konica Minolta bizhub 250 All-In-One Laser Printer
Chawanwit Klanarong
Level 1:
Habit-Forming:
New Friend:
  • Contributor 26 Answers
  • Posted on May 08, 2016
Chawanwit Klanarong
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
26
Questions
0
Helped
10720
Points
75
It you look no matching paper from the computer, print it.
setting printer properties,settings defaults,original size select to match.
1 Related Answer
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Oct 09, 2008
SOURCE: konica minolta
How about this, if you look what paper tray are avaible from the display pannel, is there a matching size paper tray or is the tray you are trying to use another size then lets say LTR. Is it a different size, if so you may have paper jamed behind the paper tray causing a different paper size, if so remove the jamed paper..... Also, the other suggestion are good as well.
Solution for error code 005-196
This is essentially a paper size mismatch which causes a paper jam. Technically you submitted a print job for a paper size that did not match the paper which was fed into the printer. Example, your document is legal size but the printer pulled a letter-size paper. As it passes through internal sensors along the paper feed path, the paper size doesn't match the document size (created on the PC) and so the printer stops with the paper in its path posting the error and causing you to have to remove the paper from the jam area. The resolution is either provide the correct size paper based on the document settings in the PC application (may need to be fed in the printer's manual paper tray) or change the document size within the PC application to match the size of the paper being fed into the printer. (Paper size can also be modified in the printer settings on the PC.)
Keeps telling me to load correct paper into tray 2 (says unexpected paper size 41.3)
Hello pls match the paper size in tray manually & printer setup . go to page setup & match the size as well as set manualy in tray2 & same in printer driver page setting your problem will be resolved 100%.
1helpful
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
My Brother MFC-9420CN printer is telling me to check the paper size. How do I do this?
Check to make sure the document your sending matches the paper size you have in your paper tray. The reason its telling you to check the paper is because your document size and paper loaded aren't matching
1helpful
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Konica minolta
2helpful
Machine telling me wrong paper size i have reset and reloaded but not working
Check the guides in the paper tray to make sure they match up to the proper position for your paper size. If for instance the paper tray is set to A1 by accident and you are using letter paper, then you request to print on letter sized paper the printer will think it doesn't have letter paper available and will ask for some. The position of the guides in the paper tray are what tells the printer what size paper is in that tray. Otherwise your paper settings in the paper meny are wrong as this can override the paper tray settings, check them to make sure they match the paper size in the trays also.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
