Need service manual or part number for rf tuner
SOURCE: programming help
Try to buy another manual (univesal remote control) because its not easy for you to get the codes if it will not work the write to us again.
SOURCE: vcr
Yes you may hook that up to the coaxle end of this unit or the RCA scart connection on the back.
The coaxle end you would need to be on channel 3 or 4 make sure you verify witch channel you vcr is under. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Unable to program my Time Warner Cable remote to Symphonic TV
the instructions are on the back of the remote. if lost. you have to:
1) Turn tv on ( i would suggest turning it off then on)
2) Press the Device you want to sync (tv)
3) Press and hold the setup button it will blink once...let it blink twice before you go to the next step.
4) press 9-9-1
5) press the power key on the remote
6) press the channel up (CH +) button repeatedly until the device (tv) turns off.
7) when it cuts off immedieately press the setup button.
