Transfer data from compaq armada 1571dm to modern computer/laptop. no means of using usb stick, sd card, or burning cds on this old compaw armada 1571dm
Remove the HDD, you will need one of these: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554 USB 2.0 to IDE/SATA Adapter Cable
SOURCE: compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
SOURCE: Please help me with my COMPAQ ARMADA 1700
Double check to make sure there is no floppy disk or CD-ROM disk inserted when you boot. If there is definitely no floppy or CD, your hard drive may have crashed or been corrupted. You can try installing Windows again, but it might not work if your hard drive is faulty. If it's faulty, you'll need to head to the local computer repair shop or have a geek friend help get and install a new one, then reinstall Windows.
SOURCE: compaq armada 1580DMT
Sound's like you've had a hsrd drive crash. The message 32768 kb ok is a memory test, this indicates that something went wrong with the operating system the last time it was shut down. It should, after the memory test, either correct the system problem or give an error code. Since it does nothing, this indicates that the hard drive has failed and, unfortunately, needs to be replaced.
SOURCE: my usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
SOURCE: Compaq 6910p Notebook does not recognize a SD-MMC
If the memory card is recognized and readable in a USB card reader, the memory card is fine. If the 6910 does not recognize the memory card, either the card is not properly seated in the 6910 card reader slot, the card slot is not connected to the main board of the 6910 or you need a DIFFERENT device driver for the 6910.
