Ran dishwasher and a few hours later display was off, would not start. replaced fuse, still nothing.
The Samsung DMR57LFS Dishwasher has a 15 Amp/250VP Volt Fuse located on the lower right side of dishwasher behind an aluminum panel held by two screws. Pull dishwasher out from counter, remove lower rectangular aluminum panel, and it is just inside underneath. Unscrew fuse holder and replace fuse. I had to pay a Samsung Authorized Repairman $109.70 to replace a simple fuse. I learned the hard & expensive way. Samsung won't tell you to check the fuse underneath the unit. They won't even tell you that there is a fuse underneath on the right side. The fuse protects the Printed Circuit Board or Blue LED Control Panel in the event of a power surge or lightning strike.The less than $4.00 fuse will blow first.
Call chas&son,s at 579-379-0993 and they will come out the same day no less okay
