It doesnt want to read my memory card, it just says memory card not inserted, i did inserted the right way its just stopped reading it while using it, what can i do?
Have you try other memory card ? If other card works then means your old memory card is broken. You need a new card !!
In fact I sell cheap 4Gb memory card ...
If its more than 8GB it wont work. If its less than 8gb then put it into card reader on your computer and reformat the card. If that doesnt help or you computer doesnt recognize it either obviously the card is bad.
1. Does your PSP have a customized firmware (CFW) already?
2. If you just bought a new PSP, definitely it can not read the games inside the memory stick. You need to upgrade the original firmware of your PSP into customized firmware CFW.
The best way to check if the memory card has the problem or the memory slot is bad is to try a different card and see if the PSP will read it if it reads a different card so the old card is bad but if it wont read a different card the slot is bad and need some repair........
ok if the stick is to small it wont work but what are you really trying to do! mod it well here is how you do it!!!!!!!!!!!!!!!!! http://forums.afterdawn.com/thread_view.cfm/688507 read about five comments down!!!!!
It might be that the SD card's format isn't right for the psp to read, if you have a psp usb cable you might be able to change the sd card to the right format via CPU.
