When i bought the unit it was getting hevey and when i moved it had water coming out of the bottom of the unit and think the unit is full of water it has a small drain at the back so do i drain it from their?
SOURCE: DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
SOURCE: Just bought the Delonghi portable
Ah man, like any other 'computer issue' these days - I'm sure you've already 'turned it on and off' a few times - (if not - I'd try that, and plugging it into the outlet and unplugging it). Also, I would try removing the tank (which you might have already done) and re-installing it. There might be a 'lever/manual device' that you can pull or push that would reset it - but not likely, but - I would try to find something like that - and re-position it in different ways to see if that would reset the switch.
Look on the cord/remote control for a 'reset button,' and maybe the user's manual will have some trouble-shooting hints that will address the problem.
good luck
SOURCE: DeLonghi Portable AC PACL90 --
just keep it unplugged and let it dry out as much as possible. Yes you can replace the hose contact customer service here.
800-865-6630
you may be able to purchase through this link check it out.
http://www.delonghi-accessories.com/index.php?cPath=61_49_264
Product manual purchase here
http://www.delonghi-accessories.com/product_info.php?cPath=184_185&products_id=572
800-865-6330 DELONGHI CUSTOMER SERVICE
FixYa Premium Support
Please accept solution and rate 1,2,3 or 4 stars Asked. Thank you.
