One of the USB devices attached to my computer has malfunctioned, and windows does not recognize it. For assistance in solving the problem, I clicked the message. The recommendation was to try reconnecting the device. If the it wasn't recognized replace it. I checked unknown device properties. Unknown device Device type: Universal Serial Bus Controllers Manufacturer: ( Standard USB host controllers) Manufacturer.
SOURCE: computer does not recognize usb device
Go into the settings menu, from there, go into usb mode...there are two settings: mtp & msc... my player was using mtp and wasn't being recognized, so I switched it to msc, and the computer recognized it.
SOURCE: problems with computer connection
Unplug your computer for 30minutes
I know it sounds crazy, but I had the same problem and that fixed it... on top of that I couldnt even turn it on.. but now everything works after doing that trick.
SOURCE: coby 1g C582 unknown device
I HAVE THE PROBLUM THAT THERE IS NO DISK IN DRIVE H PL INSERT DISK DRIVE PL TELL ME THE PROBLUM
SOURCE: usb malfunction
I can help you with you Coby 610 mp3 player.
What is happening is that your Coby isn't communicating properly with the computer. You don't need a driver, you just need to repair the Coby's system software.
Replacing the
firmware in your mp3 player should have it working like
new again.
Please try these steps to fix your Coby MP-610
MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
