Question about HP OfficeJet Pro k550 Printer
My Office Jet Pro k550 won't pump ink from only one colour, the cyan. Will an HP cartridge help?
I'm currently using aftermarket toner. cjc
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Should, try cleaning the heads of the one that don't pump ink with achol and swab
Posted on Jan 26, 2013
6ya staff
SOURCE:
Anonymous
  • 73 Answers
SOURCE: where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Posted on Apr 11, 2009
Jerry Umali
  • 979 Answers
SOURCE: I have problem with my HP business ink jet 2230.
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Posted on Sep 16, 2010
Michel Smith
  • 1218 Answers
SOURCE: My HP Office jet Pro
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the printer cartridge check the following steps :
  • Turn on the lid of the printer and then remove the cartridge from the printer head.
  • Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
  • Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Oct 12, 2010
TabTreeJunki
SOURCE: My HP Officejet 6500 Wireless
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
Posted on Jun 20, 2011
Gary Howard
SOURCE: hp office jet pro k550 printer will not print the
Try updating the printer driver. If that fails, then this problem may be mechanical in nature.
Posted on Oct 18, 2011
HP Officejet Pro K8600 won't print in color, just in black
Ink levels are an estimate. They are approximated according to how much color might have been used. You may be out of all the color inks, they may be dried out or clogged. There should be a head cleaning operation for the printer, but it uses ink too.
Feb 07, 2018 | HP OfficeJet Pro K8600 Printer
My HP Officejet Pro K550 is not printing the cyan (blue) ink. It has a new cartridge. I've run print quality pages and configuration pages -- no cyan shows up. I cleaned the printheads and no c
Do a test print...
assuming you have done multiple print head cleans... if it fails to print ANY cyan, I'd guess the print head is dead... although to be honest im not an expert with this hp printer. if that is the case, it probably isnt worth repairing.
If it does print some cyan, just missing, you may be able to find info, sorry, I cant help you there, on accessing the service or maintenance mode and doing a higher level clean, if your printer supports that.
As a last option, disassembly and soaking the bottom of the print head in cleaning solution /water... overnight, without getting ANY water on any contacts, then re running print cleans.
good luck
in my exp, again, not with this printer, mind you, if a print head fails to print ANY ink for a given colour, the print head is usually faulty.
Hope this info helps
May 15, 2012 | HP OfficeJet Pro k550 Printer
Hello my 7590 printer will not print in cyan
The chances are you have a defective cyan ink cartridge. If you are using an aftermarket/reloaded cartridge and the cartridge chip is defective. First try a new cartridge. The best bet is a new OEM cartridge, run the deep cleaning utility 3 times. The nozzle may be clogged and this will clean the nozzle.
Aftermarket/reloaded cartridges ink do not always meet the specifications for the printers that use the finer inks.
Let me know if this works for you. Thanks.
Mar 07, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
My machine is hp officejet pro K850
Sometimes when you unplug devices for 5 to 10 minutes the memory resets. This my help if not let me know.
Dec 14, 2009 | HP OfficeJet Pro k550 Printer
Whant to buy Hp 88 Printhead
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=501369&lc=en&cc=ca&dlc=en&lang=en&cc=ca
click "Shop For Supplies" to access:
https://h30042.www3.hp.com/SureSupply/
Which of the HP 88 cartridges:
C9385AN HP 88 Black Officejet Ink Cartridge
C9386AN HP 88 Cyan Officejet Ink Cartridge
C9387AN HP 88 Magenta Officejet Ink Cartridge
C9388AN HP 88 Yellow Officejet Ink Cartridge
do you need to order?
Nov 20, 2009 | HP OfficeJet Pro k550 Printer
Reports cyan cartridge empty but it is not
please remove all catridge
clean inside on the catrdge place space
put back the catridge
Oct 29, 2009 | HP OfficeJet Pro k550 Printer
XEROX PHASER 8550
Do you have the operators manual? Run it through a cleaning cycle. Also Xerox's website will guide you through some maintenance steps. If you are using generic wax, you may have clogged the jets.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 02, 2007 | Xerox Phaser 8500/DN Printer
HP OfficeJet Pro k550 Printer Logo
109 people viewed this question
Ekse
Thomas F. Schneider
