All cycles work, but the machine won't agitate, During the agitate cycle there is a noise lok like starting but stop' The fill, spin, rinse, and drain cycles all work fine.I check the belt is look good,With out laod of cloths it works.Any suggestions about how to troubleshoot or fix would be appreciated. thanks
the agitator wasn't working. took the cover off and found idler pulley had come off, plus the belt was all chewed up.
washer leaks from the bottom of the tub
Ge washer wsbr3140d0ww fills, agitates, won't drain. Checked pump, pump works, no clogged hose, changed lid switch, changed timer and pump still won't cycle in.
machine fills up , no agitation, cycles to spin cycle and rinse cycle, which both work works.
