Whirlpool LER5636P Electric Dryer Logo
Posted on Jan 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Humming noise, runs and stops thru out drying process.
I posted this problem earlier today. I have a whirlpool front load dryer, it is making a humming noise, it runs for a few minutes and then cuts off. after resting for a few minutes it automatically starts up on it's on. if i push the start button it will not start. it always starts up on it's on. the dryer dries well but it runs and stops all through the drying process and the humming noise is unbearable. please help....
Bill Dickerson
Level 3:
  • Master 979 Answers
  • Posted on Feb 04, 2009
Bill Dickerson
Master
Level 3:
Answers
979
Questions
0
Helped
309480
Points
2196
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 • Dryers
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Whirlpool Carbrio dryer buzzing noise while running. Works OK just keeps buzzing off and on while drying. Not a grinding sound.
OK, remove the 2 screws on the front lower kick plate. Run the dryer to see if the buzzing is coming from the motor or from the burner area. Post back your results.
1helpful
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
New Maytag dryer model mgdc400vw makes loud humming noise
Weird, try making sure it is level, and make sure your vent pipe aint too long. Tip the cabinet back while running if the noise goes away the damn metal vent pipe is too dang long.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
LOUD NOISE WHILE DRYING
remove the back cover that covers the lint trap. there is a fan blade back there and some foreign object is probably hitting the fan blade
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
62helpful
21answers
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
